Cutting back on radiator drag - Page 2 - Fuelly Forums
Old 03-28-2006, 04:44 PM   #11
basjoos's Avatar
Sorry about the repeat
Sorry about the repeat portings, I am having some slow connection problems with my dial-up service this evening and thought the posting hadn't gone through.
aerocivic.com
Old 03-28-2006, 10:23 PM   #12
Matt Timion's Avatar
Re: Sorry about the repeat
I think it's not just you. THe server is slowly getting more sluggish. I'm officially taking my quest to find a better server seriously starting tomorrow.
Old 03-29-2006, 01:34 AM   #13
krousdb's Avatar
Re: Since engine idle-stop is
krousdb, I have been going to the www.cleanmpg.com site and haven't had any problems with accessing other boards. I'll keep working on the problem and see what I can work out.
Basjoos, are you still having problems accessing cleanMPG?
Old 03-29-2006, 01:36 AM   #14
krousdb's Avatar
Re: if you engine kill a lot
Originally Posted by philmcneal
if you engine kill a lot then you don't have to worry about engine over heating right? But wouldn't that prevent the cooling system from circulating in the engine? How about that Oil?
basjoos and krousdb can you post pics of your block? I wonder if it distracts from the car's image?
My Prius has had a bazillion starts and stops. At 63K miles, it has never been back to the dealership since the day it left. I do my own oil changes. No problems so far.
YOu can see my grille block in one of the pics in the Airspeed Indicator thread. Currently, it is made from a spare roof shingle. Soon it will be made from coroplast.
Old 03-29-2006, 04:54 AM   #15
basjoos's Avatar
I still can't log on. My
I still can't log on. My username and password are apparently registered on the board, because if I enter a different username and/or password or use a different combination of lower/upper case letters, it gives me a "invalid username or password" page. When I use the correct usename and password, I first get a "Thank you for logging in" page, then it goes to the "You are not logged in or you do not have permission to access this page" page. Maybe my account never got activated? E-mails have been known to vanish in the aether.
aerocivic.com
Old 03-29-2006, 06:14 AM   #16
i have noticed that doing more engine-off coasting has resulted in my cooling fan coming on more frequently. but i think this has less to do with the grille block, and more to do with shutting off the engine after a high-load event:
if i go a couple of blocks between 2 stops, i'll accelerate approximately halfway, then kill the engine and coast to the next stop. in other words, the engine is killed just after a relatively high load (and i mean relatively - accelerating at a gentle pace), when it's generating more heat.
that heat isn't immediately dissipated because the water pump stops pumping when the engine stops (unlike the prius, which has an electric pump, and which may continue pumping after the motor is shut off).
what this means is FAS *may* subject a normal motor to higher temperature peaks and hot soaks than normal driving. also, since the stationary coolant in the radiator cools more rapidly with the engine off while coasting, the engine is subjected to wider coolant temperature fluctuations when restarted than an engine driven constantly.
it reminds me of a bit of advice a knowledgeable old timer gave me once, which is you shouldn't shut an engine off immediately after exiting the highway (high load) because the cooling system won't have had the chance to dissipate the built up heat.
whether it stresses engine components (head, head gasket?) to the point of affecting longevity, i can't answer.
something to think about.
Old 03-29-2006, 03:17 PM   #17
krousdb's Avatar
Re: I still can't log on. My
I sent Tom another message. I will get back to you with what he says.
Old 03-29-2006, 04:20 PM   #18
krousdb's Avatar
Basjoos,
Please check your private messages. I will send you something.
Mobile App and Multiple vehicles? Furrner Fuelly Web Support and Community News 5 11-26-2012 08:03 AM
Fully doesn't always post to Facebook at fuels-up b1gted Fuelly Web Support and Community News 1 07-08-2012 02:14 AM
Spark plug mod zpiloto General Fuel Topics 56 08-28-2009 07:47 PM
Volkwagon Creates Fuel Efficient Prototype - 235MPG!!! Bunger Automotive News, Articles and Products 26 05-05-2006 11:59 AM
1989 Suzuki Mini Truck iburnh2o For Sale 0 04-02-2006 05:57 AM
