Accurate way to measure idling fuel consumption - Page 2 - Fuelly Forums
Old 10-21-2010, 03:45 PM   #11
FrugalFloyd's Avatar
Re: Accurate way to measure idling fuel consumption
That sounds abnormally high to me. My 2.5L SE-R consumed .22 gph at idle, and my 1.5L xB sips about .14 gph.
Old 10-21-2010, 03:47 PM   #12
I don't know much about these new engines, is there any way to make it idle lower? Idle seems high, around 900 RPM.
Larry1LT is offline   Reply With Quote
Old 10-21-2010, 04:24 PM   #13
Custom tuning is the proper way to lower the idle. It would involve using a special computer cable and special software to edit the car's computer programming.
If available for your car it is probably going to cost a couple hundred dollars and beware that you'll be asking someone who usually deals in tuning to increase racing performance to do the opposite of what he usually does.
It may be possible to do an awful hack on the Idle Air Controller or electronic throttle, but the computer will probably find a way to compensate and will almost certainly throw a code/set the Check Engine Light.
Old 10-21-2010, 08:48 PM   #14
I might be able to talk the dealership into looking at it, since it's brand new with no modifications. I think the idle is too high, shouldn't it be closer to 750?
Old 10-22-2010, 04:57 AM   #15
You'll need to check with other 2010 Forte Koup 2.0 automatic owners to find out what their idle RPM is. If you ask the dealer they'll just tell you it's normal. Even if you go in telling them that similar cars idle lower they'll probably still tell you it's normal...but being confident will help.
Old 10-22-2010, 09:17 AM   #16
I wish I had a throttle cable like the old days, things were so simple back then.
Old 10-22-2010, 10:04 AM   #17
I'd agree if I wasn't struggling with a carburetor that makes no sense.
Old 10-22-2010, 10:12 AM   #18
I enjoyed working on my 1991 Toyota MR2. No Carb, but equally retarded AFM (air flow meter).
Old 10-22-2010, 07:12 PM   #19
OMG!! I figured it out guys, I put my car in N when idling and the GPH went to 0.18! That's a huge difference from 0.30-0.34 GPH when in D!
I even tried putting it in N during coasting and my iMPG went from 120 to 180-200 MPG! This is so awesome lol.
Old 10-23-2010, 03:02 AM   #20
Good work!
When putting it back in D, rev-match to reduce the extra wear on your transmission. Know from experience how fast your engine will go once you put it in D, and rev the engine to that speed just before shifting.
