My WAI - Page 8 - Fuelly Forums
Old 06-22-2009, 04:42 PM   #71
Turn on the a/c. My IAT rises 30 - 40 degrees with the a/c on.
Old 06-22-2009, 04:44 PM   #72
Is that one of your dry jokes? No A/C in my vehicle, alas.
co de pen den cy
Function: noun
Date: 1979
Old 06-22-2009, 04:55 PM   #73
No, I'm serious. My IAT rises a lot with the a/c on.
Old 06-22-2009, 04:59 PM   #74
Yes, but is that useful from net overall energy savings point of view? Thermodynamic humor, gets me every time!
co de pen den cy
Function: noun
Date: 1979
Old 06-22-2009, 05:08 PM   #75
I'd say its at least a break even. Being as the truck gets better mileage at highway speed with the windows up & a/c on. The higher temps, with a wider throttle position will allow the engine to run more efficiently with less pumping losses.
Old 06-22-2009, 05:15 PM   #76
That's cool then. Nice energy recapture.
co de pen den cy
Function: noun
Date: 1979
Old 07-08-2009, 09:20 AM   #77
Showed my WAI setup to my mechanic and for once he didn't think I was crazy (our winters are pretty cold). He thinks that I may simply be sucking off all the heat that the relatively low surface area manifold can provide, limiting my temp. He suggested making a surround for the catalytic converter (it's mounted vertically right below the manifold). Not sure when I'd get around to that exactly, but it's food for thought.
Oh, and he thought my interior mirror project was crazy, so I got my fix on that score.
co de pen den cy
Function: noun
Date: 1979
Old 07-11-2009, 07:38 PM   #78
guest001's Avatar
if you look at factory intake heaters on like TBI. all they are, is a dyer pipe connected to a pipe welded onto the heat sheild. you could easily weld a 2.5 or 3" OD pipe on a heatshield and run a dyer hose from it to where the stock box inducts "cold air"
guest001 is offline   Reply With Quote
Old 07-15-2009, 04:41 AM   #79
But wouldn't get nearly as much benefit from that ^^ unless you block off the cold air source as well.
I think Jay's IAT's raise w/ A/C because his secondary fan kicks in (assuming he doesn't have a clutch fan hooked up, but even if he does, idle picks up and the fan pulls more). When that happens, more air is pulled through the condensor, then the HOT radiator.... and into the intake.
But yes, sometimes A/C use at highway speed is beneficial from the aero advantage of windows up.
John
'09 Saturn Aura 2.4L
'96 Chevy C1500 (5.0L 5sp)
'01 KTM Duke 2
Old 01-16-2011, 12:52 PM   #80
KLP
Re: My WAI
I have read this complete thread in hopes of getting info results if the WAI actually helps MPG?? Maximilian can you give us some before and after numbers on MPG?
KLP is offline   Reply With Quote
Can't delete fill ups posted by a friend. missmaispace Fuelly Web Support and Community News 4 08-18-2014 09:18 PM
Average mpg + tracked km even though fuel-ups marked as missed Pelle Fuelly Web Support and Community News 14 03-04-2012 03:10 AM
Best ever tank notification - 1st time only? bedbug Fuelly Web Support and Community News 6 05-23-2010 01:51 AM
Good bye Good Mileage?? bsams General Fuel Topics 50 10-17-2008 04:20 AM
Readers driven to...save on gas bowtieguy Automotive News, Articles and Products 3 07-07-2008 03:51 AM
