Ultra-Gauge beats ScanGauge at ~1/3 the price - Fuelly Forums
Old 08-24-2010, 09:58 PM   #1
FrugalFloyd's Avatar
I bought an Ultra-gauge at an introductory price of $39.95 after shipping, and after a $9 rebate.
I drove my test loop in my xB with the UltraGauge and ScanGauge II, back-to-back. The UG is a fully-capable drop-in replacement for the SG. It behaves nearly identically to the SG, reporting the same distance and mpg as the SG, both under cruise control, and under full-FAS P&G conditions. At the end of my loop, under cruise control, the UG and SG displayed 9.6 and 9.7 miles. I adjusted calibration on the UG, based on the same fuel consumption, and it came out the same 13.5% calibration factor as the SG.
One quirk of the UG is its trip mpg average display is the impg display for the first minute after you do a trip gauge reset. At first, I thought it was a distance issue, but it turns out to be a time issue. Instead of an average value, the display jumps all over the range, from 15 mpg climbing hills, to 200+ mpg descending them, until that first minute passes. Another quirk is the UG keeps accumulating trip mpg, miles, and fuel consumed until you reset them manually from the gauge menu. Following photos show the main and gauge menus.
The only visible difference with P&G is the UG displays 000 mpg during a FAS, and the SG displays 9999 mpg. Both UG and SG displayed 9.3 miles driven under P&G. I got about 53 mpg in cruise control with both SG and UG on the 9.6 mile test drive, and 62.0 mpg P&Ging the same route. Next two photos show UG FAS and pulse displays. Note the open and closed loop displays, respectively, in the upper right portion of the UG.
I love the quick interchangeability of the UG. I plugged it into my wife's Hyundai, and it scanned the KWP2000 protocol and found 33 gauges within a minute. I plugged it into my Scion, and it found an 11 bit CAN protocol and 44 gauges, including barometric pressure, again within a minute. In order to get barometric pressure shown for the Scion with the SG, I had to experiment with the xgauge coding for all the listed protocols, a process that probably took an hour. Plus I spent more time testing the SG for my SE-R and my wife's Hyundai, only to find they don't display barometric pressure. With the SG, you have to program every possibility, knowing that if LF4 works, LF1-3 probably won't work.
After the UG does its quick scan, it displays its software revision # (mine is ver. 1.0 dated 8/13/10, just a week before I ordered mine), # gauges, whether or not the car has a fuel sensor, its type of mpg sensor (MAF or MAP), and its OBDII communication protocol. Following photo shows completed scanning display, and has a size comparison of the SG and UG. The display shows 43 gauges, but the initial scan said 44 were found. The missing gauge is open/closed loop.
You go to the main menu's Vehicle Setup choice to set engine size, fuel tank size, and calibration. Calibration is a breeze, because you can enter fuel in .001 gallon increments. So after my 9.6 mile drive, I was able to enter .181 gallons of gas, and get a 13.5% calibration factor long before I could do it with the SG. As I mentioned, the calibration value is the same for both the SG and UG in my Scion, probably indicating they use the same method of calculating mpg for MAF systems.
Another improvement of the UG over the SG is it warns you of pending trouble codes. My xB routinely gives a nonsense P0000 TC. The UG started showing me a pending trouble code 25 miles ago, and gave me the option of disabling the alarm. I'm letting it run to see how it handles it.
The UG is a better hypermiling tool than the SG, at roughly 1/3 the price.
Old 08-25-2010, 02:12 AM   #2
Re: Ultra-Gauge beats ScanGauge at ~1/3 the price
Since my SG died I decided to try this esp. at the price (it's on the way). I will add my own review to supplement this one if the OP doesn't mind. this certainly looks better than the SG. we'll see how it handles the southern heat.
Old 08-25-2010, 03:41 AM   #3
Arrow Re: Ultra-Gauge beats ScanGauge at ~1/3 the price
Looks cool, but my SG is already paid for. If it broke I'd consider getting one of these.
Old 08-25-2010, 04:42 AM   #4
That looks great! It looks like there's finally some real competition for the SG, maybe even beating it at its own game. If I could grab one for $40 now I'd jump in it.
Edit: They need to update their ads...their sponsored result on eBay says $39.95 but when you click on it it takes you to their website which says $59.95...
Edit 2: I guess it wouldn't really make sense for me to get it now, my next DD won't be OBDII.
Old 08-25-2010, 06:21 AM   #5
Interesting. I didn't know about the UG until now. I think my SG was $160 or so. Now I am thinking of possibly getting an UG for the other car.
Thanks for the link and your comparison write-up Sentra.
Dave
GasSavers_GasUser is offline   Reply With Quote
Old 08-25-2010, 07:17 AM   #6
Feel free to share your experience with the UG in this thread, Philip1. The UG automatically dims under extreme high temperatures, as a cooling safety measure. Hopefully that will be enough for your southern heat.
Old 08-25-2010, 01:59 PM   #7
I forgot, and left my UG in my xB's window in full sunlight in 100 degree weather for hours today. The internal temp display showed 173 degrees when its alarm temperature is 145 degrees. The UG worked fine as the Scion'x AC cooled it down. The alarm went off when its internal temperature dropped below 145 degrees.
Old 08-25-2010, 04:54 PM   #8
good to know
the lack of feedback has hurt my milage a LOT I'm almost embarassed to post the latest fillup.
22mpg ugh
Old 08-26-2010, 04:43 PM   #9
I had the opportunity to find out what happens to the UG display under DFCO today, as I drove the xB to lunch, and had some long downhill coasting. The UG simply ignores DFCO, and continues to display (for instance) 168 or 233 impg down the hill. When you think about it, there really isn't much difference over a 500 mile tank, between idling down a 1 mile hill at .2 gph or 0 gph.
Old 08-26-2010, 05:03 PM   #10
The difference between DFCOing down the hill and neutral coasting + braking down the hill is the same as that of EOC.
Can it measure EOC properly?
epa estimates cseverens Fuelly Web Support and Community News 2 06-09-2010 03:48 AM
MPG rally in Washington is a conditional 'go' bones33 General Fuel Topics 12 05-03-2009 07:13 PM
tire warped because of too much psi kickflipjr General Fuel Topics 30 04-24-2007 12:09 PM
