Catch 22 - Page 2 - Fuelly Forums
Old 04-04-2006, 10:30 AM   #11
Compaq888's Avatar
this is my steering rack and
this is my steering rack and the line is pointing to the ripped boot.
Old 04-04-2006, 10:47 AM   #12
Not an expert, but...
I'm not a mechanic by any means, but it looks like right above the boot is the place where your steering column meets up with the rack and diverts pressure onto the piston to move it back and forth. The tubes you see running to the shaft are the pressure lines that "help" the rack to move more easily.
Actually, if you have a leak from your boot, there may be a bigger problem here. The boot is merely a protector for a stronger seal. It sounds like inside the boot, the seal is failing. Some PS "Stop-Leak" might do the trick (available at any auto parts shop).
Lastly, it looks like the only premature wear would occur within the piston (minimal) and at the column/rack gear possibly more significant. It looks as if the PS fluid may actually lubricate this gearset (my mistake earlier). The trick is, if you can seal-off the system with some fluid still in it, then it will continue to lubricate the whole works, but if it leaks out, then that's nil.
Bascially, picture the inside of a liftgate strut or the storm-door closing mechanism -- similar concept of hydraulic/pneumatic piston function.
Old 04-04-2006, 10:47 AM   #13
Matt Timion's Avatar
Re: Guys where did you get the
Originally Posted by rh77
I don't believe it's really an issue of lubrication. I think the PS pump is simply a hydraulic assist device that receives input from the steering wheel and helps it along through a high-pressure line to the steering rack. All of the other components are sealed and have lubrication of their own. I'm not sure which boot is leaking exactly...I'm thinking it's where the pump line meets the rack, right?
I'm unsure if Nissans are like Hondas or not, but I know with a Honda the PS fluid actually lubricates the steering rack. If you want to remove PS you have to either swap racks or get a kit that maintains a small amount of fluid to lubricate the column.
Old 04-04-2006, 10:56 AM   #14
After I saw the schematic that was posted, I started to realize that it's probably integral in lubrication. I know it would ruin the rack for the life of the car, but what would happen if you put heavy gear grease in there and disconnected the PS, and seal up the rack? I'm just trying to picture the Honda manual steering system -- basically the column hooked to a gearbox that translates the motion (and I assume in the box is filled with heavy grease).
Old 04-04-2006, 10:57 AM   #15
Compaq888's Avatar
Hopefully it's just the
Hopefully it's just the boot, because the dealer was very hesitant to fix my current system. If they open it up and find out something else is broken it would be better just to replace the entire rack.
The boot doesn't even look ripped it's leaking where the ring sits on top of the boot to hold it down to the rack.
Old 04-04-2006, 11:00 AM   #16
Re: Hopefully it's just the
Not sure, but that doesn't sound good. Honestly, try the "Stop-Leak" stuff. I fixed a radiator leak with a similar product and an old Oldsmobile transmission.
Old 04-04-2006, 11:05 AM   #17
Compaq888's Avatar
what is the brand of
what is the brand of it???
And if it doesn't stop the leak, what's next?
Old 04-04-2006, 11:12 AM   #18
Dunno
Bascially you know that wall of all kinds of automotive fluids at the parts store -- in there somewhere is called "Power Steering Stop Leak". Different companies make it, so there will be some choices. I think any brand will do. If that doesn't work, we'll escalate to "Plan-B" as necessary.
Old 04-05-2006, 02:20 AM   #19
why it leaks
rh77 has a great point - the boot only protects the exposed shaft of the rack that travels through the seal so that the seal does not get damaged. If the seal is leaking then there probably is damage to the shaft (nick or scratch) and or the bushings holding the shaft centered in the seals. You already have a bigger problem and I don't think you are going to get away cheep at the dealers. Next test is to see if turning the wheels under heavy loads makes it leak more.
Old 04-05-2006, 02:30 AM   #20
Compaq888's Avatar
I won't know if the seal is
I won't know if the seal is leaking unless I put a new boot on and it leaks again.
MiniStat Idea - Avg Miles / Day, Week, Month bullrider General Fuel Topics 1 10-28-2011 04:32 AM
RSS feed for friends activity udtrev Fuelly Web Support and Community News 2 07-26-2009 12:47 AM
Suggestions needed Matt Timion Fuelly Web Support and Community News 80 03-28-2009 05:37 AM
Well, I bought the Miata... LincolnW General Discussion (Off-Topic) 5 07-13-2006 12:36 PM
Commuting Calculator kickflipjr General Fuel Topics 5 06-21-2006 07:12 PM
