Electric conversion: Project ForkenSwiift - Page 47 - Fuelly Forums
Old 04-01-2007, 07:21 PM   #461
Originally Posted by Silveredwings View Post
I wonder if there is a worthwhile way to "recondition" them. I've read of some rejuvenating methods
I haven't looked into this yet, though I have seen the word "desulfator" floating around various places.
I had an idea for upping the supply of used batts which may work out. I've charged the car a few times now and started monitoring individual battery charges - some of them are quite healthy. Others are toast - and of course the pack is only as good as its worst batt, so there may be hope.
Originally Posted by Peakster View Post
Does this mean that ForkenSwift will be your new daily driver?
Nah, my old 10-speed will remain the daily driver!
Originally Posted by Brock View Post
And yes after resting from a full charge should be 6.3 per battery or 37.8 for the string.
Thanks for that info. I may pick your brain with more questions...
I am seeing 6 amps when full. I'll have to double-check the charging voltage, but I think it's around 45.
Originally Posted by rh77 View Post
Any plans?
Nothing yet. "Custom paint" will entail sanding the rust spots off and coating with colour match! Actually, I seriously want to put a racing stripe on it. Irony defined.
Old 04-01-2007, 07:23 PM   #462
Parts: a nut, some tubing, and the highly unique "banjo bolt"
Hey, nice work! Very nice indeed.
Old 04-01-2007, 08:00 PM   #463
BTW, I made and uploaded a neat 5-minute video of the first drive activities. Just waiting for YouTube to process it and spit it back out.
Today: added 2 more batts to the string, for a total of 48v. This made a noticeable difference; it turned the car from "interesting science experiment" but too slow to be practical, into a barely usable car. At 48v, it would never handle the cut & thrust of typical urban traffic, but as an NEV equivalent on the side streets of a small, quiet city, it'll be fine.
With some effort (EV hypermiling!) I managed to go 5.x km around the neighbourhood today on one charge (but 3 separate journeys).
I also started documenting individual battery voltages after each run to see if I can figure out which batteries are weakest. Turns out driving around the neighbourhood is an excellent "load test" procedure - the bad batteries are quick to reveal their true selves, relative to their pack-mates.
Old 04-01-2007, 11:00 PM   #464
http://www.youtube.com/watch?v=bDERyAILOak
Old 04-02-2007, 04:12 AM   #465
Moderator
GasSavers_DaX's Avatar
Great video Darin!
Old 04-02-2007, 04:22 AM   #466
zpiloto's Avatar
Man that is so cool!! What kind of shape are the batteries in after the test drives? Nice rolling stop by the way
Old 04-02-2007, 05:03 AM   #467
I was thinking that since you have a ready supply of used batteries, you could continue to collect them, charge them, load test them, and then keep the ones that do the very best. You will probably find a lot of really bad ones, but all you need is 8-10 really good ones, right?
Nice video. It really is amazingly quiet. You might need some sort of very soft horn or beeper to use in parking lots and near pedestrians so people don't step out in front of you. Something that plays the sound of George Jetson's spacecar would be perfect. :-)
Also, is there an concern about hydrogen buildup in the charging area? I don't know much about batteries.
Old 04-02-2007, 06:43 AM   #468
zpiloto's Avatar
This is a very good point. I have had this happen quite a few times in the Prius. Folks just assume that if it's not making noise it's not moving.
Old 04-02-2007, 06:54 AM   #469
Hybrids will end up with some sort of government mandated ICE-off noise generator before long. That will be a sad day.
Old 04-02-2007, 07:42 AM   #470
Tuggin at the surly bonds
Silveredwings's Avatar
That's terrific! Thanks for showing us the current state of the tests you're conducting. I was shocked to see that the Neon guys got a charge out of it too.
by Bill in Houston: Nice video. It really is amazingly quiet. You might need some sort of very soft horn or beeper to use in parking lots and near pedestrians so people don't step out in front of you. Something that plays the sound of George Jetson's spacecar would be perfect. :-)
That's what I was thinking.
Combined totals of all my vehicles? nizationpcs Fuelly Web Support and Community News 0 03-30-2009 06:41 AM
Converting numeric to current tire sizes. omgwtfbyobbq General Maintenance and Repair 5 06-01-2007 04:51 AM
Prius. First Impressions zpiloto General Fuel Topics 17 09-03-2006 10:49 PM
